Source Transformation
Discussion in 'Homework Help' started by p75213, Aug 14, 2011.
  1. p75213
    May 24, 2011
    39
    Hi Guys,
    I would appreciate if somebody could give me a hand with the attached exercise. It's easy enough to solve using nodal analysis but I am feeling a bit stumped trying to solve it using source transformation.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Show as your attempt to solve the problem so that we can help you.
  3. p75213
    May 24, 2011
    39
    Well I can't replace the 4A current source with a voltage source because then current ix disappears. If I replace the dependant voltage source with a current source I get a dependant current source of 2ix/5 A parallel with a 5 ohm resistor. I cant combine the 5 and 10 ohms resistors as current ix disappears.
    I am pretty much stuck at this point.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    You are doing good job with the problem.
    You can not simplifier the circuit more. So all you have to do now is to star finding Ix.
  5. p75213
    May 24, 2011
    39
    It's easy enough to then find ix using nodal analysis, however I can't see the point as it was simpler to do this first up without bothering with the source transformation.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    You could also do it this way.
  7. p75213
    May 24, 2011
    39
    Very elegant tnk. I think this is the solution the authors intended.
