Source for 6 pin connector to fit PICKit3?
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Dec 11, 2009.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,176
    I am trying to find the male 6 pin connector that will fit into the PICKit3. TI am odering a bunch of other parts from Mouser but the only connector that I can find looks like even close to working is not stock. I found these. Am I looking in the right place?
  2. BMorse
    Sep 26, 2009
    2,675
    234
    These are known as SIP PIN HEADERS >> You could cross this digikey part with mouser, but I didnt see any stock... http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ED7206-ND
    Sometimes they come in longer pieces (more positions up to 72) and then you just break off however many pins you would need...
  3. eng1
    Oct 25, 2009
    13
    You have to search for a male 6-pin header with 0.100'' (2.54 mm) spacing. Pins must be square.
    You may look at page 1392 of Mouser catalog: http://it.mouser.com/catalog/640/1392.pdf
    I haven't bought the headers from them, but it looks like you can find the correct one there.
  4. spinnaker
    Oct 29, 2009
    5,065
    1,176
    Thanks found them!
