Source follower design
Discussion in 'General Electronics Chat' started by usyed, Jun 2, 2011.
  1. usyed
    Mar 5, 2011
    7
    Hello
    Can anyone help mewith an example of a source follower circuit. My input impedance needs to be very high. Can someone provide me the model number of the mosfet that can be used for simulation in Multisim tool?
    It would be great if I get the resistance and capacitance values in the design as well.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. usyed
    Mar 5, 2011
    7
    Thanks for replying; however, I do not want to use an opamp, I want to use a mosfet for high input impedance.
    Can you please tell em which mosfet would be good? I also do not know the values of resistors/capacitors to use. I need help with the design, not the concept:)
    Your help will eb much appreciated.
  4. Bernard
    Aug 7, 2008
    4,239
    414
    Check out " electrometer ", using OP amp , achieved 10 to the 12th Ωs input Z.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Can you tolerate the offset (several volts) of a source follower? Are you aware that you can buy op amps with MOSFET input transistors?
