; USING A LM35CZ sensor on AN2, Vref (AN1)set to 2,56Volts gives 1mVolt =0.4bits,
; Sensor gives out 10mVolt per degree C= 4 bits per degree
; because we are using upper 8 bits, there is an automatic divide by 4, so 1 degree =1 bit
; 0 Deg to 100Deg'C= 0mV to 1V output from sensor =0 to 1024 bits.
list p=16f690 ; list directive to define processor
#include <P16F690.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _CPD_OFF & _BOR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _FCMEN_OFF & _IESO_OFF
; 4Mhz clock
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
errorlevel -302 ; suppress banksel warning messages during assembly
errorlevel -311 ; suppress HIGH operator warning messages during assembly
org 0000
goto Main
;***** VARIABLE DEFINITIONS
cblock 0x20
RESULTLO ; temp regs for routine
RESULTHI
Set_temp
d1
d2
d3
endc
Main
; set up registers ***************************************************
BSF STATUS,RP0 ;Bank 1
BCF STATUS,RP1 ; set up status bits
MOVLW b'01010000' ; A/D 1/8 osc =2usec a/d time at 4mhz clock
MOVWF ADCON1
BSF TRISA,0 ;Set RA0 to input
clrf TRISC
clrf TRISB ; set port c output
BCF STATUS,RP0 ;Bank 2
BSF STATUS,RP1 ; setup status bits
clrf ANSEL ;****************** portc to digital i/o
BSF ANSEL,0 ;Set RA0 to analog
clrf ANSELH ; set port b/c to digital I/O
BCF STATUS,RP1 ;Bank 0
clrf PORTB ; clear output ports
clrf PORTC
goto Begin
Temperature
MOVLW b'01001001' ;Left justified(bit 7), Vref(bit 6 ,1=external source), AN2 source input(bit 3) temp i/p
MOVWF ADCON0
call Delay
BSF ADCON0,GO ;Start conversion
BTFSC ADCON0,GO ;Is conversion done?
GOTO $-1 ;No, test again
MOVF ADRESH,W ;Read upper 8 bits
MOVWF RESULTHI ; store upper 8 bits
MOVF ADRESL,W ;Read lower 2 bits
BCF STATUS,RP0 ;Bank 0
MOVWF RESULTLO ; save lower 2 bits
return
Begin
call Temperature
movfw RESULTHI
movfw PORTC ; display temp on leds
goto Begin
end
// Lcd module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End of Lcd module connections
void main() {
unsigned long frequency; // complete frequency count
unsigned long freq_low; // low word of frequency count
char freq_txt[11]; // buffer for ASCII conversion
unsigned char ch; //
unsigned int adc_rd; // Declare variable
char *text; //
long tlong; //
ANSEL = 0x04; // Pin RA2 is configured as an analog input
ANSELH = 0; // Rest of pins are configured as digital
TRISA = 0xFF;
/*ANSELA = 0; // Configure PORTA pins as digital
ANSELB = 0; // Configure PORTB pins as digital
ANSELC = 0; // Configure PORTC pins as digital
ANSELD = 0;*/ // Configure PORTD pins as digital
ADCON0 = 0; // A/D off
ADCON1 = 0x0f; // all digital
CM1CON0 = 0; // disable 18F45K22 comparator
CM2CON0 = 0; // disable 18F45K22 comparator
TRISB = 0; // PORTB is output
PORTB = 0x00; // Initialize PORTB
//LATA = 0; // all off
//LATB = 0xff; // disable GLCD if fitted
//LATC = 0; // all off
//TRISA = 0xC0; // all output except OSC pins
//TRISB = 0x00; // all output
//TRISC = 0x01; // all output except RC0
Delay_ms(100); // Wait for LCD to stabilise
Lcd_Init(); // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Lcd_Out(1,1, "Frequency on RA2"); // Print text to Lcd, 1st row, 1st column
Lcd_Out(2,1, "00 Hz "); // Print text to Lcd, 2nd row, 1st column
adc_rd = ADC_Read(2); // A/D conversion. Pin RA2 is an input.
tlong = (long)adc_rd * 5000; // Convert the result in millivolts
tlong = tlong / 1023; // 0..1023 -> 0-5000mV
ch = tlong / 1000; // A/D conversion. Pin RA2 is an input.
//PWM1_Init(2000); // Test frequency PWM1 module
//PWM1_Start(); // start PWM1
//PWM1_Set_Duty(127); // Set current duty for PWM1 50%
T2CON = 0b00001111; // T0 on, 16 bit, prescaler 256
T1CON = 0b11000101;
//T1CON = 0x85; // T1 on, ext input, no prescale
//1GCON = 0x00; // no gating
while(1){
TMR0 = 0x85; //0b10000101 // set up timer 0 for 1 second time out
// Timer register
TMR0 = 0xee; // writing TMR0L also writes TMR0H
INTCON.TMR0IF = 0; // reset time-out indicator
frequency = 0; // initialise count
TMR1L = 0; // reset to 0
TMR1H = 0; // reset to 0
PIR1.TMR1IF = 0; // initialise
while(!INTCON.TMR0IF){ // wait for 1 second time-out
if(PIR1.TMR1IF){ // monitor frequency count overflow
PIR1.TMR1IF=0; // reset overflow
frequency += 65536; // increment count high bytes
freq_low = (TMR1H << 8) + TMR1L; // collect frequency bytes
frequency += freq_low; // collect frequency bytes
LongWordToStrWithZeros(frequency, freq_txt); // covert result to ASCII
Lcd_Out(2,1, freq_txt); // Print text to Lcd, 2nd row, 1st column
// LATA=LATA^1; // show some life by toggling LED
by Jake Hertz
by Jeff Child
by Duane Benson
by Jake Hertz
