souped up ultrasonic range finder
Audioguru
Joined Dec 20, 2007
11,248
The lousy old LM358 dual opamp has hardly any gain and output above 5kHz.
An MC34072 dual opamp works fine with a 5V supply and with frequencies up to 100kHz.
NewStudent
Joined Feb 16, 2008
25
Just as a suggestion, what if you place a short across the receiver temporarily. If you continue to see a signal on the oscope, then you have to conclude that at least some of the output is electrical noise rather than acoustical in origin.
hgmjr
Thanks for your suggestion, I blocked the receiver with my thumb - no signal. I blocked the transmitter with my thumb - no signal. I shorted across the receiver – no signal. I disconnected the receiver - no signal.
Conclusion the problem is acoustic crosstalk.
