i am using a meteor smoke particle detector for a sounding rocket project.The output of my detector is current in range pico amps to micro amps.i need to convert it into voltage in the range 0-5v(for the adc).what can i do??
Just curious, how accurate and calibrated do you think a design like this would be? It isn't what I would call instrumentation.http://www.electronics-lab.com/projects/test/011/
Here is a high input impedance amplifier that might be of some use. Seems fairly simple in design.
Just one day left to complete your project? Better burn some midnight oil on this one.
As usual, a total lack of specifications. The range given so far covers about 6 orders of magnitude. It'd be nice to narrow that a bit.What is the problem?
by Aaron Carman
by Duane Benson
by Aaron Carman
by Aaron Carman
