sound proof material
Discussion in 'General Electronics Chat' started by bug13, Sep 29, 2014.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    What kind of off the shelf sound proofing material I can easily buy from supermarket or local hardware store? I am looking mainly sound proofing human voice.
    Will cotton works? or foam? I assume I need some sort of foam with the right gap size or something??
    Thanks guys!!
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Home depot, 8ftx3ftx1/2" insulation foam board $7.00.
    or 1" for ~$18.00.
    Smaller? 3/16 " project foam board from art/craft supplies.
    Max.
  3. #12
    Nov 30, 2010
    16,704
    7,351
    Fiberglass insulation, if you have room for several inches. Cotton will work, but it's flammable and it's hard to get cubic yards of the stuff. Spray foam works, but again, it's flammable.
    As usual, google is your friend.
    http://www.soundproofing.org/
    http://soundproofing101.com/
    sirch2 likes this.
  4. nsaspook
    Aug 27, 2009
    3,014
    2,368
  5. quarkelec
    Apr 1, 2014
    Nice topic.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    a real cheap sound deadning material, dirt. hollow walls filled with dirt.
    bug13 likes this.
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    How much attenuation do you require?
    Where are you going to use this? in a stud wall? on top of a wall? floor?etc...
    Seeing you are from NZ I'd suspect what they have in their "supermarket" or "local hardware store" is quite different from what might be available to me..
    A "supermarket" in the US is where you buy food/milk/bread,etc...
    Bread will work :) for a little while anyways..
    foam eggcrates?
    rubber mats?
    acoustic foam?
    regular fiberglass insulation works wonders too..
    bug13 likes this.
  8. sirch2
    Jan 21, 2013
    1,008
    351
    Agree with #12, fibreglass insulation or sheep wool
  9. Shagas
    May 13, 2013
    802
    74
    How about rockwool?
  10. #12
    Nov 30, 2010
    16,704
    7,351
    Rockwool is an older form of fiberglass. Works pretty much the same as fiberglass.
    bug13 likes this.
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    Of course, lead sheeting is also great. ;)
    More seriously, if you are trying to sound proof a wall between adjoining rooms, consider whether it is just the air between the two wall faces or do the studs also transmit sound. In other words, a dense stud (supporting structure inside the hollow wall) will communicate sound. In American construction, we commonly use 2X4 studs with drywall or sheet rock on both sides. For better soundproofing, it is recommended to build a 6" wall with alternate 2X4 studs attached to either face. Add fiberglass etc. woven in and out of the studs like a basket to help. That way, the only direct connection between rooms is the floor and ceiling. You do have to consider the ceiling, especially if it is a suspended ceiling.
    John
  12. #12
    Nov 30, 2010
    16,704
    7,351
    It all comes down to, "How much attenuation?"
    Enough guessing. Please give us a number of decibels to get rid of.
  13. Lestraveled
    May 19, 2014
    1,957
    1,218
    Back in the "day", we used egg cartons stapled to the wall. Without the eggs of course. A layer of muslin fabric over the top completed it.
    bug13 likes this.
  14. bug13
    Feb 13, 2012
    1,213
    38
    I don't have a number, I am more like playing around and experiencing stuff here. :)
    I am more thinking the hardware section of a supermarket here :)
  15. sirch2
    Jan 21, 2013
    1,008
    351
    Some replies on here got me thinking, is there a difference between anechoic and soundproof? Seems to me that the egg box approach is generally used in anechoic (no echo) applications, e.g. recording studio, but may not be the best at sound proofing, i.e. stopping sound coming through a wall.
  16. GopherT
    Nov 23, 2012
    6,315
    4,038
    The sound proofing foam that looks like egg cartons is sold at a big premium over plain slab foam. The interesting part is that it is so easily made. Drill an array of holes into two sheets of plywood, add 2" dowels to each hole. Compress the foam between the two sheets of dowels, cut while compressed. Instant egg carton.
  17. mcgyvr
    Oct 15, 2009
    4,791
    976
    egg crate foam absorbs higher frequencies compared to flat sheet foam.
  18. nsaspook
    Aug 27, 2009
    3,014
    2,368
  19. Stuntman
    Mar 28, 2011
    189
    50
    Realize they do make a Great Stuff in a fireblock version.
    Walls are generally insulated for sound (as well as temperature) with fiberglass, but realize the wooden studs rigidly anchored between the drywall provide a medium for sound to propagate through.
    #12 likes this.
  20. #12
    Nov 30, 2010
    16,704
    7,351
    I have a feeling that, "soundproof" is a misnomer. Maybe somebody, somewhere, has a really dead acoustic space, but for us normal humans it's a matter of attenuation. I made a room that is 51 decibels below the room that is 9 inches away, and I think that was a good accomplishment for the materials available.
