Sound generator chip question
tedstruk
Joined Oct 8, 2016
12
If I hardwire a board with a sound generator chip, do I have to make multiple sound speakers(like a klaxon horn here and a passive subwoofer here) to get the different sounds, or is the chip capable of ouputting the different sounds? The chip data says it can produce different sounds, and it has 8 outputs. So do I hardwire all the outputs to one speaker system? Or do I need to supply the sound circuits individually?
I want to build a failsafe kit for a motorcycle startup sequence that will identify the individual systems(good or bad) with different sounds, as a testing bed for electric starting system components.
tedstruk
Joined Oct 8, 2016
12
The Chip is a GI SOUND ay-3-891it says 3 independently programmed analog outputs. Interface to most 8 and 16 bit processors.
AnalogKid
Joined Aug 1, 2013
11,044
The three outputs are independent, so if you need only one channel and basic sounds, then the other two can be ignored. Note that this is a fairly difficult chip to program and control.
ak
