Sound Frequency counter design
Discussion in 'The Projects Forum' started by Nutball, Jan 29, 2016.
  1. Nutball
    Jan 29, 2016
    20
    For those who like designing circuits, I have a little project for you. I like designing too, but I know so little I'm not sure how to go about making a frequency counter. Devices with the capability I'm looking for are way out of my price range, and I'm hoping that building my own simple version will be much cheaper.
    Here's what I want to accomplish:
    I want to be able to, for example, measure the sound of a whistle and have a digital or analog display show the Hz, preferably to the hundredths of a hert with a measuring range of at least 20-18,000hz or 1-20,000max. I would like it to choose the loudest frequency it hears for measuring like how a tachometer for an RC airplane propeller measures the strongest pulses of light out of all the pulses it sees. I want to build it myself if there are no such devices readily available at a low cost. It can be analog or digital, a design I don't have to program, calibrating is OK if needed. Simplest and cheapest design with precision to 1hz, preferably to .01hz
    What I would like from you are suggested parts and how they should be configured. If a special programmed processor is required I may consider compensating someone for making it.
    I hope this is the right place to ask about such a project, where you may do most of the designing. Thanks
  2. blocco a spirale
    Jun 18, 2008
    1,460
    369
    Here's what you need to do:
    1) Pick up mobile phone
    2) Download spectrum analyser app
    3) Install spectrum analyser app
    4) Enjoy your new spectrum analyser
    absf and Lestraveled like this.
  3. Nutball
    Jan 29, 2016
    20
    My phone is too old, it still has a singular background with the orange X shaped guy. Thanks for the attempt at a very easy solution, I wish I had a smart phone.
  4. Nutball
    Jan 29, 2016
    20
    Can I get an app to work on my computer? There has to be an app for that right :)
  5. absf
    Dec 29, 2010
    1,493
    374
    The second easiest way is to use a 16F628 pic and build a frequency counter based on this chip. There are many design based on this and you can just google "16F628 frequency counter" and you'll be able to find one.
    The next easiest way is to build this old 1980 3-chip design from Radio Electronics 1980 Dec issue. It was based on the intersil ICM7216 chip with LED display...
    The project pdf and the 7216 datasheet are attached fro your reference..
    Allen
  6. panic mode
    Oct 10, 2011
    1,328
    305
    google did not help...?
  7. dannyf
    Sep 13, 2015
    2,196
    417
    You may check your local music stores or ebay. They have sound calibrated that do just that. Roughly 10 USD each, complete with battery, display and microphone.
  8. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Googling "frequency counter app windows" gives several hits for freeware.
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  10. Nutball
    Jan 29, 2016
    20
    I'll look into those designs to build. I found the audio frequency counter app which is exactly what I want as it shows hz and can be tuned to filter out other sounds. I've been burning up data today trying to figure out how to run it on windows 7. Just so you know, the app I mentioned is an advanced version of what I want, the spectrum analyzers and instrument tuners are not really what I want. I'll post an update as I figure things out. Thanks for the help so far.
  11. Nutball
    Jan 29, 2016
    20
    The 16F628 based counter looks like it could work, but many designs out there are for measuring crystals. I found a kit for one, but I hope it would be easy to make it work with a microphone input and turn it's 50mhz ability into precision as I don't need to measure above 20kHz. I wouldn't know where to start in terms of modifying it until I become familiar with how the chip works.
