sound circuit resistor
Discussion in 'General Electronics Chat' started by Eric007, Aug 29, 2012.
  1. Eric007
    Thread Starter Senior Member
    Aug 5, 2011
    1,054
    33
    Hi All
    Attached is a little circuit I will be workin on this weekend...
    On the right side of the circuit is a resistor 'R2: 22-220 ohm' meaning that a resistor value between 22 - 220 ohm needs to be chosen in order to not pass very high a sound level into my speaker. The resistor will be connected to a PWM channel.
    The speaker I am using has the following specs: max.0.2W, 8ohm!
    Any help in choosing the appropriate value of the resistor will be appreciated!
    Thanks!
  2. Eric007
    Aug 5, 2011
    1,054
    33
    Nothing for me here!? :)
  3. #12
    Nov 30, 2010
    16,665
    7,310
    So, what's that box? Personal Computer? PIC microcontroller? Power Contributor? Phase Circuitry?
    The way it's drawn, it has zero volts to work with so the resistance doesn't matter. Zero volts divided by any resistance = 0 watts.
  4. Eric007
    Aug 5, 2011
    1,054
    33
    It a PIC microcontroller!
    the left side of the box is a potentiometer that will be connected to ADC
    the right side of the box (PIC mcu) PWM channel!
  5. #12
    Nov 30, 2010
    16,665
    7,310
    Assuming a PIC uses 5 volts as a supply and you are outputting a sine wave, you would need 3.18 ohms to protect the speaker...if that's what you're trying to protect. If there is a limit on the current a PIC can output, and that is what you are trying to protect, that is another matter.
  6. Eric007
    Aug 5, 2011
    1,054
    33
    Thanks for your reply!
    PWM will output a square wave...
    the resistor to be chosen is between 22 and 220 ohm and says it is needed in order to *not pass too high a sound level into your speaker* (I gave my speaker specs in OP).
    I am not too sure sure what it means myself! but by the look of things (diagram) what is that *resistor* for?
    thanks!
  7. #12
    Nov 30, 2010
    16,665
    7,310
    The way I calculated it, the speaker does not have enough wattage capability to survive a sine wave you can make out of 5 volts, in the long run...so 3 point sumthin' ohms will cure that.
    A square wave contains twice the power of a sine wave so the math is wrong.
    Now you need at least 14.36 ohms to protect the speaker. If you have a 15 ohm, 1 watt, 1% resistor, use that. If not, use a 22 ohm, 1 watt, whatever tolerance, resistor.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    It must be a very cheap tiny speaker since it is rated for only 0.2W. An earphone?
    If the resistor is 15 ohms and the speaker is 8 ohms then the load on the PWM circuit is only 23 ohms. A PIC cannot drive such a low impedance.
    If the PIC is driving a power amplifier with zero output impedance then the 10uF capacitor into the 23 ohms load causes a loss of frequencies below 696Hz.
  9. #12
    Nov 30, 2010
    16,665
    7,310
    I kind of hinted at that but still don't know the current limit for a PIC.
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    The maximum allowed output current of a PIC is 25mA peak. It will have a voltage drop.
    A PIC might produce 4V p-p when the peak current is 25mA. Then the minimum load impedance is 2V peak/25mA peak= 80 ohms.
    The peak power into 80 ohms is 50mW and the RMS power is 25mW which is almost nothing.
    Eric007, absf and #12 like this.
  11. Eric007
    Aug 5, 2011
    1,054
    33
    @Audioguru: Thanks for your reply Sir!
    So if I got you right, your suggested resistance value is 80 Ohms, right? as you have in post #10.
    Just a curious question, what would happen for instance if one chooses 220 ohm?
    thanks again!
  12. #12
    Nov 30, 2010
    16,665
    7,310
    The power supplied to the speaker will diminish according to Ohm's Law (V=IR)and Watt's Law (P=IE). The DC blocking capacitor mentioned in post #8 will have a lower frequency limit as derived from Xc=1/(2 Pi F C)
  13. Audioguru
    Dec 20, 2007
    9,411
    896
  14. Eric007
    Aug 5, 2011
    1,054
    33
    Here's what I am trying to acheive:
    Generating a continous sound that varies between two frequencies by varying the voltage (0V to 5V) on the ADC channel using a potentionmeter. The PWM will generate that sound!
    I don't need no code (can do it myself!) but rather a right approach to solve the problem.
    Here's what I have in mind:
    Given a 10bit ADC resolution, we have the following:
    Assuming the two limit frequencies are 200Hz - 3000Hz
    0V -> 0 (ADC value) -> 200Hz
    5V -> 1023 (ADC value) -> 3000Hz
    I think there should be some kind of mapping between ADC values and frequencies, correct?
    Varying the frequency would result in different sounds but continuous!
    My first concern is how many different sounds would be reasonable to have? so I can do set a number of frequencies between the limits!
    Am I also correct to say that a certain range of ADC value must correspond to a specific frequency!?
    for instance, 0 - 30 (ADC) -> 200 Hz
    31 -61 (ADC) -> X Hz
    Maybe I don't even have to have equal interval frequencies, huh?
    Any comments would be appreciated!:)
  15. Eric007
    Aug 5, 2011
    1,054
    33
  16. Audioguru
    Dec 20, 2007
    9,411
    896
    usually the carrier freq
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    Usually the carrier frequency of a PWM circuit does not change. The modulation frequency is changed to vary the audio frequency. The PWM can also vary the loudness.
    Your cheap tiny speaker might not produce a frequency as low as 200Hz and might not produce a frequency as high as 2kHz.
    Some people are not interested in music because to them a low frequency sounds the same as a high frequency.
    What is your waveshape?
    A square-wave sounds like a buzzer, a triangle-wave sounds something like a violin and a sine-wave sounds something like a flute.
    The attach and decay times determine what instrument produces the waveform.
  18. Eric007
    Aug 5, 2011
    1,054
    33
    Thanks Sir for your reply!
    my waveshape is a square-wave! I must have frequencies between those two values!! so how to solve this problem? changing the speaker or that R2 resistor?
    Also I think I will ignore the 2 Msbs in the result of the ADC and just use the 8 LSBs to make things simpler when mapping ADC results to frequencies...
  19. Markd77
    Sep 7, 2009
    2,803
    594
    The frequency of the PWM module isn't 10 bit, it's a bit more complicated than that.
    The duty cycle is up to 10 bits, but that isn't important.
    The period (1/frequency) is a combination of the PR2 register which is 8 bits and the prescaler which is either 1, 4 or 16 (other PICs may vary, I looked at the 16F819 datasheet). Working with the PWM module gives me a bit of a headache. Try making a spreadsheet with the available frequencies. You will find that they aren't evenly spaced and a lot of them are higher than you want. If your highest frequency is only 3000Hz, you can get a decent range of frequencies just in code without bothering the PWM module, you get 166 instruction cycles in each half of the period at 3000Hz with a 4MHz PIC.
  20. Eric007
    Aug 5, 2011
    1,054
    33
    Thanks Sir for your reply...
    I made a huge mistake when typing...I actually meant *10 bit ADC* :) sorry for the confusion!
    I will only consider the 8 bit Lsbs of the ADC result...Yes sound frequencies are Not evenly spaced as shown in the above link...
    I will make 32 different sounds...
    ADC result from:
    0 - 7 will correspond to 200Hz
    8 - 15 -> ...
    16 - 23 -> ...
    Then instead of comparing ACD result with 32 values (ie from 0 - 7 to 248 - 255) and using a 'cpfslt f' which is an instruction that does not exist in PIC16F ...can create it t will make code unnecessary complicated and will use too many instruction cycle...
    what i will do is have a table with 256 entries, ie table index values will the the same for 8 entries...ie 0-7, 8 -15, ....so I will use the ADC result as index and have the table return a value corresponding to the frequency 'PR2' and fed it to wherever I have to feed it to for square wave output...
    I will cooksome code and present it to the big boy in case I run into a problem...but I dont think so...maybe with ADC 'acquisition time'...but I'll see
    Thanks and comments are always welcomed:)
