Sound AMP circuit needed
Discussion in 'The Projects Forum' started by Kldnz, Feb 27, 2016.
  1. Kldnz
    Feb 8, 2016
    17
    hello! I wanna make a little project to learn ironing... and can anyone show me a sound amplifier circuit and give me a component list if you have one laying around some where? I would really appreciate that!
  2. GopherT
    Nov 23, 2012
    6,303
    4,027
    If IRONING means soldering, then it would recommend a small LED flashing circuit.
    There are many discrete (2-transistor) LED flashing circuits available on the Internet.
  3. Kldnz
    Feb 8, 2016
    17
    already did that want more complex like amp ;/
  4. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Have you tried google?
  5. GopherT
    Nov 23, 2012
    6,303
    4,027
    Then try an LM386. It makes about 1watt and is a single chip with some external components. It is generally the first audio amplifier most people make. Google LM386 datasheet. The circuit is near the end of the datasheet.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You will find quite some links on this page of the EDUCYPEDIA:
    Audio amplifiers
    Bertus
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,686
    1,297
    There are many small audio amplifier kits available from 1 W to hundreds of watts.
    ak
  8. Kldnz
    Feb 8, 2016
    17
    Thank You
  9. Dodgydave
    Jun 22, 2012
    5,143
    768
  10. ian field
    Oct 27, 2012
    4,447
    791
    The TDA7052 uses less components and gives decent power out at low Vcc - the A suffix part has DC volume control.
