Sound-activated mp3
Discussion in 'The Projects Forum' started by bbucky, Oct 16, 2007.
  1. bbucky
    Oct 16, 2007
    6
    I am trying to design a circuit that will have a mic that triggers an mp3 player to play a message when it detects a sound.
    There are some really cheap mp3 players now and I was thinking I could connect a mic to a potentiometer to give it some adjustability and then have it control the play button of the mp3 player with a transistor. As you can tell I'm a real beginner in electronics and I'm not sure if this is even possible. Would it just keep the play button on or is there a way to make this a "momentary" circuit like the play button on the mp3?
    Also, can I connect the output of the mp3 player (speaker) back to the mic circuit so that it will prevent the mic from triggering again while the mp3 is playing? I imagine a transistor with an inverter so that while there is current to the speaker it keeps the mic circuit open. I think a 555 timer would do it but the disadvantage is that it would not automatically change the duration of blocking the mic with different mp3 durations.
    I hope some of this makes sense. I'm still learning.
  2. HarveyH42
    Jul 22, 2007
    425
    5
    A while ago, I bought a few 16 meg mp3 players, surplus store. I've got a simple circuit some place for making one play when power is applied, just a transistor, capacitor, and a resistor. Will post it if I find it, been a while. Never got around to finishing that project. Basically wanted to have it play a song after the sun went down, all solar powered. Needed a bigger amplifier, more battery power, and no idea how to turn it off after the song was done (would continously loop).
  3. mozikluv
    Jan 22, 2004
    1,437
    a schmitt trigger set up with a time delay of say 5 to 10secs, using discrete parts could do it for you:)
    moz
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Try an internet search using the terms "sound activated switch." You should find at leas half a dozen schematics if you dig long enough. Pick one or two that you think you could handle making, and we'll go from there.
  5. bbucky
    Oct 16, 2007
    6
