Sound Activated LEDs
Discussion in 'The Projects Forum' started by laconic, Oct 11, 2011.
  1. laconic
    Oct 11, 2011
    Hi I am working on a project to make multiple towers of LEDs that are sound activated to use for live set ups in DJ gigs. I am rather new to circuits but have been toying around with the Velleman MK103 kits. I basically need help with figuring out how to power more than just the four LEDs from the kit. I tried just wiring out to additional LEDs but they are not powered very well, and I would prefer to run each tower off of one MK103 if possible. Any help would be appreciated. Here is the circuit diagram for these boards:
    http://forum.allaboutcircuits.com/image_cache/httpkj6ead.hackhut.comfiles201108VellemanMK103.png
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. iONic
    Nov 16, 2007
    1,422
    68
    What color LED's are in the kit. Essentially you will need a much larger voltage source.
    How many LED's would you like to power with each kit?
  4. laconic
    Oct 11, 2011
    The kit comes with four 5mm diffused red LEDs, and I want to power about 25 to 30 5mm blue LEDs with each kit.
  5. KJ6EAD
    Apr 30, 2011
    1,426
    364
    A 24V or 36V supply could be used for both the LEDs and the control board. A few passive components on the control board would have to be changed but the transistors are rated for 45V so they can handle the higher voltage. If you have one of the MK103 kits unassembled, you can set up the circuit on a breadboard and test the modifications with the new power supply.
    You will need to wire the new LEDs in series strings of 5 or 6 for a 24V supply or more for a 36V supply. Each string of LEDs will need a current limiting resistor and you'll need an appropriate driver transistor either as a substitute for T4 or driven by it.
  6. laconic
    Oct 11, 2011
    Great thanks for the help, I will try that out and see how that works.
