This is my first post on here and I am new to electronics, for I am a programmer and lack the knowledge of the electrical engineering.
With this is mind I have created a circuit to light a LED from the input of a mic element. The circuit works correctly for if the sound is soft or loud the brightness of the LED reflects it.
Problems:
- Since this circuit will eventually be running on batteries, and the batteries will lose voltage, the resistance set from the potentiometer will need to be constantly be readjusted.
- The LED does not get bright enough unless it is right in the mouth of the speaker.
Is there a better way of achieving this?
Thanks for your help.
Here is the circuit diagram-----
Problems:
