sound activated led
Discussion in 'The Projects Forum' started by sharpy, Aug 7, 2010.
  1. sharpy
    Aug 7, 2010
    10
    Hoping this is faily simple, I want the build a simple circuit to test an audio output.
    Upon any audio being detected I want the LED to light, fairly simple I hope! I am going to plug this into a headphones output.
    Im a bit of a novice at this, would appricate any help including circuit diagrams, components etc... I can manage the soldering, just [​IMG]
    thanks
    sharpy
  2. Externet
    Nov 29, 2005
    780
    58
    At what audio level do you want the led to turn on, and what is the impedance of the headphone output ?
  3. sharpy
    Aug 7, 2010
    10
    approx 60 ohms for the headphones (would happen if this was too low or high? )
    the sounds are from 20dB to 100dB
    does this info help?
    thanks for the reply
  4. Externet
    Nov 29, 2005
    780
    58
    Try TWO same color leds connected together in counterparallel to the earphone jack, with no series limiter resistor and be gentle with the volume control until they lit up.
    Red, orange, yellow, green, blue leds will lit up correspondingly in the range from -1 dBu to +4 dBu or 2 to 3.5 Vpp.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Not all headphone jacks put out a ton of power, you may need to add a simple buffer circuit using an op amp or transistors. A TL082 op-amp IC would be ideal for this and the circuit woud be a snap to build since the TL082 operates as single or dual supply.
    Still haven't figure out how to upload pix jhere, or do you just link to something you've put on some webspace?
  6. sharpy
    Aug 7, 2010
    10
    counterparallel, sorry being really dim what do you mean?
    any pics or circuit diagrams re op amps would also be useful, will try the two leds today.
  7. Externet
    Nov 29, 2005
    780
    58
    Leds in counterparallel :
    A-------------------------|>|------------------------------B
    A-------------------------|<|------------------------------B
    Both A together to your audio signal; both B to ground
    For stereo, you would need another set, one for L; one for R.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have not had a chance to test this idea, but it is something I came up for my LEDs, 555s, Flashers, and Light Chasers article.
    It is something I've been rewriting forever it seems.
    R2 sets the minimum level. The idea is this is a flame simulator. I'm planning on using an AM radio.
  9. sharpy
    Aug 7, 2010
    10
    thanks for this, will do some testing tomorrow
  10. sharpy
    Aug 7, 2010
    10
    hi, a few questions
    what component is q1?
    i guess i connect the audio out to the + side of c1?
    and the opp side of r2 and q1 is the 9v battery?
    does the circuit need a ground from the headphone output too?
    thanks
    sharpy
  11. Ghar
    Mar 8, 2010
    655
    73
    There's a paper clip icon in the bar above your post when you go into "advanced" posting mode.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ground is a common lead as well as the negative connection for the battery. This is pretty much a universal electronic convention.
    Q1 is pretty much any conventional NPN transistor. I tend to use a 2N2222A, but it isn't that important.
    Your real problem is mono jacks vs. stereo. You going to have to figure out what you need to do on your side.
    Since you didn't fill out your local on the profile we can only guess what kind of parts you have access to, this is one of the reasons you see us do it.
    You can attach pictures as part of the post, or you can use the albums section AAC offers.
    How to Display Attachments Full Size
