sound activated circuit
Discussion in 'The Projects Forum' started by Morgan Rhind, Nov 21, 2008.
  1. Morgan Rhind
    Nov 21, 2008
    hi guys and girls, im very new to electronics i only have minor experiance with it.
    i would like some suggestions, this is what i need the circuit to do.
    circuit must switch on with nois
    switch off when nois stops
    must be as small as possible(but big enough to make)
    components must be available from local electronic store.
    power supply is a 6cell AA battery pack
    circuit runs a race motor
    the application of this circuit is in a paintball loader(hopper)
    the motor currently runs continuously which is noisy and draws alot of power.
    i would truly appreciate any input or links to websites that could help.
  2. mik3
    Feb 4, 2008
    4,846
    63
    You can amplify the signal out of a microphone, then use a rectifier to convert it to DC and then detect this DC value with a transistor which will drive your motor (with a relay if needed).
  3. mik3
    Feb 4, 2008
    4,846
    63
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Then the microphone hears the noisy motor and it keeps going forever.
  5. Morgan Rhind
    Nov 21, 2008
    thank you ill take a look at those circuit boards.
  6. Morgan Rhind
    Nov 21, 2008
    my consern at this stage is that it must turn off when there is no sound.
