SOT-89-5 Footprint forExpress PCB or Eagle Cad?
Discussion in 'General Electronics Chat' started by spinnaker, Oct 22, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,074
    1,176
    Does any one happen to have a footprint for SOT-89-5 package?
    Since I am familiar with Express PCB, I would prefer that but something tells me I will need to buckle down and learn Eagle CAD. :(
    Or maybe some other PCB CAD software that is easy to use? I really like how Express PCB can couple the schematic to the PCB design. I suspect Eagle CAD does the same?
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    There is a SOT-89 in smd-ipc.lbr but its not 5 lead. I would start there and edit it as necessary.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    The SOT-89-5 footprints I have seen have a pad under the chip. I have seen different shapes. I assume the pad is to help dissipate heat? So does the shape of that pad really matter?
  5. t06afre
    May 11, 2009
    5,939
    1,222
    The pad should at least have an area and shape that is slightly bigger than the conductive surface on the chip. If you use the snap/grid function in your PCB tool correct it is quite easy to draw a new footprint
