soon to be college graduate
Discussion in 'Off-Topic' started by scordova, Jan 11, 2009.
  1. scordova
    Jan 10, 2009
    I'm 20 years old, and am about to graduate with an electrical engineering degree(3 semesters left). I'm eagerly expecting graduation, but am not entirely sure what i want to do afterward. I do know that i either want to go to grad school, or find entry level employment. does anyone have insight/advice as to what i should expect after graduation?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you can afford it it might be a good time to stay in school. Jobs are scarce.
    If you think the situation is going to get much worse you might want to try for a job while they are available.
  3. scordova
    Jan 10, 2009
    thanks for the input. not being able to find an engineering job after i graduate is definitely a concern for me
  4. floomdoggle
    Sep 1, 2008
    217
    Hey Scordova,
    May seem impossible, but try to do both. Learning how to work, even if the job is only slightly related to your field, may show you what is expected of your skills. School and reality are usually two different things. Learn that as early as possible. Only the deadwood is getting laid off right now. Learn how to work, and make money; then enjoy life!
    Dan
  5. steveb
    Jul 3, 2008
    2,433
    469
    Another consideration is what type of work you want to do. If you want to do research or high level design work, then grad work is helpful and there is no reason not to at least get your Masters degree done quickly if you can make ends meet. Often you can get a graduate assistantship that pays tuition and pays you half time at a decent rate. Jobs will always be there, and a Master's degree rarely hurts your prospects.
  6. steveb
    Jul 3, 2008
    2,433
    469
    Another thought just occurred to me. When I was in your position, someone gave me some good advice. They said, "When you look for a job, look for a good boss, not a good company". That advice can be applied to grad school also. Look for a good Professor/Adviser, not a good school.
    Of course, both your leader and your institution are important, but you get the point. I've encountered many people that had bad educational experiences in grad school. It was usually the result of a bad adviser. Something similar could be said of bad job experiences.
  7. mhean_ee
    Member
    Aug 25, 2008
    10
    Practicing your course by means of a job could probably make grad school easier. If you're already working, let's say you're working as an Electrical Engineer, you could already relate those theories in school with the realities you have in your job.
    Good Luck!!!
  8. MIRINGU
    Mar 18, 2007
    75
    hI, also i would advice u if possible u can work while still in school.(being a part time learner)
