Clearly you never used a VAIO dudeWhats a one time pass?
THAT really helps with your question, doesn't it?Clearly you never used a VAIO dude
Rifaa
<snip>THAT really helps with your question, doesn't it?
I had a Vaio for several years. Updated it once. Threw it out two months ago. I have no idea what you are talking about. Hope that helps.Rifaa said:If you use a Vaio then you should know what a one time pass is and when it is needed !!! DUH!!
Not sure how you came to that conclusion, I merely tried to suggestion that "one time pass" actually meant "one time password".which means the you are not up to date on Vaio bios.
and Dave you too? you guys a like so yesterday on laptops, HUH!!
Would you believe itOK , Ok, I'll tell, it's a bios password
I only said use at your own risk because this is a power tool with the power to make significant changes to your system and I am merely covering myself in this regard. I have seen it recommended on many reputable computing forums, so its integrity is not something I'm so-much questioning.about Hiren's boot cd,never heard of it and the use at your own risk sounds creepy.
Still I'll check it out, thanks though.
Did Hiren's Boot CD not work?OOOOOOOOOOOOOOK!
This is gonna be a lesson to ya all about Sony VAIO laptop password or what ever thingy
Cause it's time to rip open this baby.
I'll post the tips and tricks once I get em formatted.
Rifaa
There are two utilities on Hiren's Boot CD for removing the BIOS password: cmospwd and cmospwc. If you have your system to boot from the CD drive then insert Hiren's Boot CD before the system tries to boot normally from disk (you either need to be fast or put the CD and reboot).Oh that, I did check em out but I could not find any thing that will erase a pass word in the bios by booting from a cd. I mean the POST is something that the bios initializes and only after that the bios boots from the CD, if the bios does not allow process anything before a pass is given how in the heck's name will the CD would ever work.
What do you think?
Rifaa
by Jake Hertz
by Duane Benson
by Aaron Carman
