Wonder if there is an internal short in the tube, Or the EHT voltage is too high, should be around 25KV. To measure that you will need an EHT probe for your meter & know how to use it.
And if the EHT is high, the tripler will arc and all the 3 tubes will produce arcing.
Besides any over voltage and the set will shut down and will blink the error code.
Wrong..I do not see the screen wire.
The tripler must be handling the screen voltages, all I see from the FB is the HV and Focus. There are two pots, but if there is one wire coming out of the rectifier area then the screen in not handled by the FBT.
It might even be located on the C board, the CRT board.
On the other hand, I see a lot of static build up around the FBT, which is the main cause of corona arcing...U need to clean the entire thing buddy, without cleaning you are just welcoming further trouble.
Clean the FBT, Tripler and the CRT surrounding area. Without cleaning you are likely to have trouble soon.
In order to see the screen voltage level, I have to see the schematic.
Your pictures is no good since the area is very tight.
See the square. The 6 pots are the 3 guns focus and screen adjustments pots.
U have to find out the faulty gun screen and reduce it until the neon glow is gone.
But after the clean up.
By the way....buy corona dope, it helps a lot. since ur TV is old
In this instance there are 3 seperate tubes with 3 seperate EHT supplys, sugesting that this one has a fault only. This is what i use to check EHT voltage & if using a HV probe its IMPORTANT to have the earth lead from probe conected to the tube earth. (this Multimeter & probe i purchased in 1977 when i started repairing TVs, No digital meters here. & it cost a weeks wage then)
