https://www.facebook.com/photo.php?fbid=1460721414148789&set=a.1401761100044821.107
the circle in red i'm in question about, not sure how to add photos
no broken wiresUmmm ! I don't think so.
Are there any unconnected wires any where?
Is it working ?
no broken wires
just one plug on board that has no wire going to it it on the left i will circle it
Need the service manual to make sure.
Ur photo's are not clear enough
need to know what that connector is on the PSU/Inverter
Any other connectors left ?
Any wires not connected to anything ?
If fan works the tacho pin might not.
Without a tacho signal from even 1 fan the set will shut down.
Check em' replace if you can
Thread starter | Similar threads | Forum | Replies | Date |
M | Sony Bravia | Technical Repair | 1 | |
9 | Sony SU-B400S operation without the bravia tv | General Electronics Chat | 7 | |
Broken sony bravia kdl 32v2500 tv fault finding help | Technical Repair | 0 | ||
K | Sony Bravia KDL-40x1000 | General Electronics Chat | 10 | |
K | Sony Bravia 40x1000 | General Electronics Chat | 0 |
