Sony battery type G np bg1 - Pinout
Discussion in 'The Projects Forum' started by vol_, May 4, 2016.
  1. vol_
    Dec 2, 2015
    93
    Here is a picture of the battery.
    I want to ask if the pin named (C) is used with the negative pin (-) for charging and (+) and (-) for operation. Is this so? If not what is going on with the battery pins?
  2. kubeek
    Sep 20, 2005
    4,689
    806
    I think there will be a thermistor connected to C so that the charger knows the temperature of the battery.
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    Internal thermistor for temperature monitoring during charge.
  4. vol_
    Dec 2, 2015
    93
    Thanks guys..
    I want to build a charger with LM338 power regulator. Questions:
    1) The charger will be connected to (+) and (-) pins of the battery then?
    2) Could i overtake this thermistor and design the charger circuit as this thermistor does not exist?
  5. Dodgydave
    Jun 22, 2012
    5,155
    772
    Yes, the thermistor will be connected to C and possibly the bat neg,.
  6. vol_
    Dec 2, 2015
    93
    So i can put the charger on (+) and (-) pins, neglecting the thermistor?
  7. Dodgydave
    Jun 22, 2012
    5,155
    772
    Yes, but its best to monitor the battery voltage and temperature using a deadicated chip.
