Sonar range finder with PIC18F452
Discussion in 'The Projects Forum' started by priyangaambanwala, Feb 13, 2010.
  1. priyangaambanwala
    Feb 8, 2010
    I want to use sonar to find distance in my robotics project which uses a PIC18F452.The diagram of the circuit is attached below (Which I found from the web). But the resource I found it says I have to use PWM to drive it.Unfortunately I am already using my PWMs for motor controlling. So can anybody tell me how to use it without PWMs alongside my program.(I'm using mikroC language.)
    Being new to PIC I don't know much about timers as well.
    Thanks in advance...
  2. t06afre
    May 11, 2009
    5,939
    1,222
    So use another microchip MCU for for the sonar range, and find a way that the two MCU can communicate.
  3. priyangaambanwala
    Feb 8, 2010
    t06afre thanx for the suggestion. but I can't afford 2mcus.(I'm using a readymade robot board. and it may be complicted.) Is there any way I can use 555 IC for the purpose? (I've seen it in IR proximity sensors to generate a 38KHz signal.)
  4. retched
    Dec 5, 2009
    5,201
    313
    You should be able to use a 555 for the PWM for the sonar transmitter. The reciever data can be interpreted by the uC.
    [ed]
    Here is a circuit using 555 for transmitter.
    http://english.cxem.net/home/home44.php
    The reciever is set as a switch, but you should be able to finagle the circuit to do what you want.
    [/ed]
