above the diagram the COM has 3.2V output. If that volts is enough for mosfet, I would like to use it. Please can i have how the mosfet work and how to put between circuit?
I change all a,b,c,d,e,f,g out put resistors to 1K. Then I supply voltage 6V~9V to com. the first digit work. about 15minutes my IC fried.
anyway thank you for your helps!
by Duane Benson
by Duane Benson
by Duane Benson
