Some sort of starter kit.
Discussion in 'Embedded Systems and Microcontrollers' started by MDMStudios, Nov 26, 2008.
  1. MDMStudios
    Nov 26, 2008
    Hey all, I am a programmer that has been programming proffesionally for the iPhone, ( Objective-C with Cocoa Touch ), and I have been wanting to start a hobby in Microcontrollers lately, but I have no idea to start. I am on a mac, and have experience in the following languages.
    C
    C++
    Objective-C
    Java
    Javascript
    CSS
    HTML
    XHTML
    I pick up languages fairly well, so based on that information is there some sort of kit/set up that you'd recommend for a noob? Thanks!
  2. mik3
    Feb 4, 2008
    4,846
    63
    If you are familiar with C then it will be fairly easy for you to program microcontrollers (uCs) in in C. Two famous companies, which produce uCs, are Atmel (AVRs) and Microchip (PICs). They both have the proper software to program their uCs in C but I am not sure if it is compatible with a MAC PC.
    Both companies have uCs with more or less the same performance and function but a reason which might make you choose AVRs is because you can find the software needed free online in contrast with PICs (you need to purchase it).
  3. leftyretro
    Nov 25, 2008
    394
    Check out Arduino ICE development board and system, AVR based that uses C/C++, open sourced (hardware and software) and avalible for Windows/Linux/Mac. Very inexpensive to get started.
    http://www.arduino.cc/
    There is also a PC application IDE using Java called Processing that can create portable PC applications that can communicate with an Arduino via serial port or USB serial.
    http://processing.org/
    Again all free and well supported with help forms and user contributed libraries.
  4. John Luciani
    Apr 3, 2007
    477
    For small uCs most programming is done in C and assembler.
    The AVR chips are well supported on Linux, Mac and PC with gcc. The Arduino
    tools consist of a java frontend for gcc and a software library. Very easy
    to setup, easy to use and free.
    (* jcl *)
  5. mindmapper
    Aug 17, 2008
    34
    Today I found an AVR development environment running on Mac OS X.
    http://www.obdev.at/products/avrmacpack/index.html
    AVR MacPack is similar to WinAVR for Windows. I'm not running Mac myself but a friend of mine was very glad when I pointed it out to him.
  6. KL7AJ
    Nov 4, 2008
    2,043
    292
    The hottest thing happening now is (are) FPGA's , Field Programmable Gate Arrays. They can be programmed with several languages, and there's a great demand now for FPGA programmers. Several development kits are available for FPGAs. They aren't cheap,,,but worth it.
    eric
