some questions ????
Discussion in 'General Electronics Chat' started by sunil_r_sp, May 18, 2007.
  1. sunil_r_sp
    Feb 18, 2007
    13
    1) We can create an oscillator using an odd no: of nand,not etc.....(since the frequency depends on the propagation delay, definitely we can achieve high clock frequency, so can we replace the crystal oscillator in our computer by this clock ?
    2) What is the exact definition of an amplifier ?
    3) What is metastability in flip-flopes ?
    4) is there something called the 'zero hold time' flip-flop ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    1. The purpose of the crystal in the oscillator circuit is for frequency stability. Substituting 3 - 5 inverter elements will oscillate, but things like temperature, power supply variation, other circuit operation, and just about any other variable will have some effect on the frequency. This is not a way to achieve stability.
    2. Google
    3. They can be in one of two states, or in a transition from one to the other.
    4. If I understand this as meaning that the set or reset state would not be latched, then what would be the purpose of that logic element?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Are you confusing this with zero order hold flip-flops?
    Zero-order hold and zero hold time are very different concepts.
    Dave
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
