some questions about timer 1 in pic 16f877A
Discussion in 'Embedded Systems and Microcontrollers' started by spidermanIIII, Jul 5, 2015.
  1. spidermanIIII
    Nov 22, 2013
    76
    hi, i have some questions about timer 1 in pic 16f877a when i read datasheet of timer 1 some register function i couldn't understand it the first what is the difference between register T1OSCEN and TMR1CS and what is meant by Synchronization in T1SYNC and what is i benefit from Synchronization
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    T1OSCEN is used to turn on and off the Timer 1 oscillator.
    TMR1CS Is used to either select the Timer 1 oscillator or the internal instruction clock as the clock for Timer 1.
