Some question about testing the internal resistance of a battery
Discussion in 'The Projects Forum' started by HTe, May 14, 2013.
  1. HTe
    May 14, 2013
    I am going to use the voltmeter-ammeter method for finding the internal resistance of a battery.Why is it necessary to turn off the switch after each reading is taken?And what assumptions might i have made in this experiment.
    PS:I am using battery bought from the supermarket, and typical school- laboratory moving-coil voltmeter and ammeter.:):)
  2. GopherT
    Nov 23, 2012
    6,340
    4,094
    Normally, when a test is done, you measure the open circuit voltage of the battery (switch to circuit turned off. This becomes your battery voltage.
    Then add a load of known resistance. Measure the battery terminal voltages again (it will also be voltage drop across the resistor). From the voltage across the resistor and the resistor value, you can calculate the current flow using ohms law.
    Now, subtract the closed circuit voltage (with load) from the open circuit voltages of the battery. Divide your voltage difference by the current flow you calculated above to get internal resistance.
    Very easy and no ammeter needed.
  3. MrChips
    Oct 2, 2009
    12,658
    3,461
    What is the voltmeter-ammeter method for fining the internal resistance of a battery?
    You should not short circuit a battery. Provide a load instead.
    You need to disconnect the load to allow the battery to recover.
  4. nsaspook
    Aug 27, 2009
    3,021
    2,392
    This is one method. http://data.energizer.com/PDFs/BatteryIR.pdf
