some one expane this circuit plz in 16f84a
Discussion in 'Embedded Systems and Microcontrollers' started by MSRH, Nov 25, 2011.
  1. MSRH
    Nov 25, 2011
    This circuit for a digital clock with date and temp.
    i need someone to tell me what are the components in this photo,
    and tell me where do the end of the floating things go ??
    is it to buttons or to V or to Ground
    plz soo important
    hent : things he use are :-
    pic microcontroller, the DS18S20/DS18B20 sensor, 4x7 segments (common anode, something like KW4-301xxx Series, or common cathode something like CC56-21SURKWA), four transistors, some rezistors!
  2. tgil
    May 18, 2011
    The arrows marked 5V go to 5V which the arrows marked 3V go to 3V. The arrows marked +5V/+3V can either connect to the 5V or 3V supply. To be on the safe side, just connect them to the 3V supply. The GND is the ground (no arrow--just a line).
    The circuit will need the firmware program loaded so that it works.
    Good Luck.
  3. stahta01
    Jun 9, 2011
    I think the +5V/+3V ones are all connected together.
    +3V goes to battery cell.
    +5V goes to external 5 volt power source.
    Tim S.
  4. MSRH
    Nov 25, 2011
    Thx guys ...
    but the arrows marked with 3V/5V ,, u will see that they maybe go to buttons ,, if it like this or what ??
    if i give u the program can any one of u guys give me a good details for it ??
