Some Help with Nimh Battery charger
Discussion in 'The Projects Forum' started by MMH, Feb 8, 2013.
  1. MMH
    Feb 8, 2013
    143
    Hello everyone! I was Thinking of making a NIMH Charger. According to what i have heard, i need an IC. Which one will be best- LM317, MAX712 or MAX713 or any other?
    Any help will be greatly appreciated!
  2. tindel
    Sep 16, 2012
    576
    196
    Which one is best depends on your requirements. I would not use a LM317 - it is a linear regulator and not intended to charge a battery.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. toffee_pie
    Oct 31, 2009
    162
    7
    you need a good understanding of electronics before going making chargers, i would use a product from Ti.
  5. toffee_pie
    Oct 31, 2009
    162
    7
  6. MMH
    Feb 8, 2013
    143
    Thanks for answering. I have read it and now know a lot more about NIMH battery charging. is Max712 better (for Nimh) or 713? Will they be able to shift to trickle charge after they are fully charged? If they are not, which IC will be better? can i use 555 timers(I know i cant.)
  7. t06afre
    May 11, 2009
    5,939
    1,222
    This page will sum it up. http://www.maximintegrated.com/datasheet/index.mvp/id/1666
    Linear or switch-mode operation, built-in termination algorithms, zero voltage slope (MAX712) Negative Voltage Slope (MAX713). Temperature and Timer Cutoffs.
    We can not read the datasheets for you. It is better that you grasp the content of the datasheet then ask for help on specific problems. But yes I think both switch a low current Trickle-Charge Rate then done charging. The MAX712/713 is one of many charge control chips.
  8. MMH
    Feb 8, 2013
    143
    Once again, thanks for answering.What does that RSense stand for(in the schematic)? Load-Isnt it optional? Cant I use an Electrolytic 1uF Cap? Cant I replace that Transistor with 2N3906? Whats a 5v+ stunt regulator? How much V and a Shall the Wall Cube produce for 1 batt-2.7v?
  9. toffee_pie
    Oct 31, 2009
    162
    7
    don't think you have the skills to make a charger, at the risk of doing some damage.
    why so hell bent on a maxim ic? texas instruments are usually the leaders for these products and have some very concise technical documents.
    Rsense is a sense resistor used to measure the current path across the circuit.
