Some help required!!
Discussion in 'General Electronics Chat' started by curriejohn, Mar 2, 2015.
  1. curriejohn
    Feb 17, 2015
    14
    Hi guys
    Is anybody able to assist me with the questions shown in the attached photo image.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The picture is not clear as the moire lines make it unreadable.
    Bertus
    PS is this homework?
  3. Dodgydave
    Jun 22, 2012
    5,167
    776
  4. curriejohn
    Feb 17, 2015
    14
    Hi Bertus
    This is part of a home study course I am currently completing to improve my qualifications to move towards changing my career. I know it may be a simple question to ask but being away from education for such along time is making it harder for me to understand things.
  5. curriejohn
    Feb 17, 2015
    14
    Is this picture any better?
  6. Dodgydave
    Jun 22, 2012
    5,167
    776
    Yes that's better, but it's still a Common Source amplifier as per post#3.
  7. curriejohn
    Feb 17, 2015
    14
    Thanks Dodgydave
    But with respect to the first image I posted are you able to explain to me the questions that are being asked.
  8. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    It's a class A amplifier.
    Capacitor on the gate: to remove any DC component of the input signal, and allow the transistor (which appears to be a MOSFET) to be biased at the desired point.
    Two resistors on the gate of the transistor: form a voltage divider, and set the voltage at the gate when no signal is applied.
    Transistor: provides voltage gain.
    Resistor on the source of the transistor: provides some negative feedback, which makes the gain of the circuit less dependent on the transistor, and also has benefits for frequency range.
    Resistor on the drain of the transistor: converts current through the transistor to voltage for output.
    My explanations are informal - the linked article above gives a much more rigorous treatment.
    bwilliams60 likes this.
  9. curriejohn
    Feb 17, 2015
    14
    Thanks Roderick
    An excellent well explained reply which is going to be very helpful for me when completing my assessment.
  10. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    No problem, but please be sure that you understand the concepts. If you're typing anything into your assessment that you don't personally understand, you'll only hurt yourself in the long run. Just saying.
    curriejohn likes this.
