Some Help about a component
Discussion in 'The Projects Forum' started by MMH, Feb 8, 2013.
  1. MMH
    Feb 8, 2013
    143
    Hello again! Sorry for disturbing you. But can You tell me what this thing is?
  2. toffee_pie
    Oct 31, 2009
    162
    7
    could be a 6.8ohm ntc.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Is this related to your battery charger question :)
  4. MMH
    Feb 8, 2013
    143
    Thanks for answering. It is not sth related to the charger. I just found it in my junk box-thought of using it. By the way how can i use the 6.8ohm ntc?
    Pardon me if i have asked too foolish questions:)
  5. MMH
    Feb 8, 2013
    143
    And is it a thermistor? I hope it is but i dont think it is.
    Pardon me if i have asked too foolish questions.:)
  6. MMH
    Feb 8, 2013
    143
    So, whats the answer? IS it a thermistors? Sorry for repeating it. I have posted it 2 weeks back!!
  7. MrChips
    Oct 2, 2009
    12,657
    3,461
    It says 6R8Ω meaning 6.8Ω
    Measure with an ohmmeter.
  8. jt6245
    Member
    Feb 18, 2011
    21
    I also think it is thermistor 6r8 ohm at 25'c with +- 20%
  9. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Not a thermistor, NTC to limit inrush current, or PTC to limit max. current.
    6.8 ohm not so easy to test maybe use a bulb.
  10. MMH
    Feb 8, 2013
    143
    Thanks for answering!! But how can I use it with a bulb? Shall it be in parallel? Can you please suggest a circuit?
  11. takao21203
    Apr 28, 2012
    3,578
    463
    In series of course. You maybe need to try a few different bulbs.
    It will be bright then turn dim for a PTC.
    For a NTC, it will be dim at first then become brighter.
    It is normal for these components to heat up.
  12. MMH
    Feb 8, 2013
    143
    Thank you very much!!
    It got brighter overtime-meaning it is a NTC. Can you now suggest a simple "circuit" using this NTC-meaning in what applications is that used??
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's a low value, so you don't want to run much voltage on it, Ohm's law and all, at 6.8 Volts, 1 amp through it, creating 6.8 Watts of heat to be dissipated. That package couldn't withstand more than about ½ Watt. Result would be "Black thingy that used to be a Thermistor".
    It can be used as a temp sensor, with low current through it, as part of a voltage divider feeding a comparator or a microcontroller. Though, the value is very small for that purpose as well, you wouldn't get a full range easily.
