Some devices that has only 1 wire! Eh?
Discussion in 'General Electronics Chat' started by Lightfire, May 30, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I looked at my dad's bicycle and saw that there is only 1 wire there! I mean the lamp in my dad's bicycle has only 1 wire! And I don't know how it is being lighted as there is no battery!:eek:
    OK, general question. How does a lamp or any other devices that has only 1 wire will work?:cool:
  2. magnet18
    Dec 22, 2010
    1,232
    125
    It has 2 wires, one of them is just disguised as the frame of the bike itself :D
    Since it's metal it can be used as the ground and save on wire.
    It's probably powered by a device similar to a small generator powered by the spinning of the wheels or the pedals.
    Lightfire likes this.
  3. Lightfire
    Oct 5, 2010
    690
    21
    Thank. :)
    Lightfire
  4. debjit625
    Apr 17, 2010
    790
    186
    Its called Bicycle Dynamo
    Read the dynamo section :http://en.wikipedia.org/wiki/Bicycle_lighting
  5. Lightfire
    Oct 5, 2010
    690
    21
    Thank
    Lightfire
  6. mbohuntr
    Apr 6, 2009
    413
    32
    Hi catapult! Your English is getting much better!! "Thank" should be changed to "Thank you" Keep asking the questions ! Your doing well. ;)
  7. Lightfire
    Oct 5, 2010
    690
    21
    :D :D
    OK
    Thank you.:D
  8. mbohuntr
    Apr 6, 2009
    413
    32
    Perfect! Well done!
  9. Jaguarjoe
    Apr 7, 2010
    770
    90
    I had a few one wire electricians working for me over the years:)
  10. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    The "one wire" idea is not limited to bicycles, either. It is commonly used in motorcycles, cars, boats, and just about any other vehicle that has an electrical system. The "negative" is usually just the frame of the vehicle itself (except for a few automobiles that are positive-grounded, and the "positive" is the frame).
    Der Strom
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is related strongly to the ground discussion we had a while back.
  12. Laird Scooby
    May 31, 2011
    11
    I tend to agree with all of what you've just said except for boats! With a fibre-glass hulls, there's no metal to provide the earth return and with metal hulls they avoid using the hull due to electrolytic corrosion. I remember sending my apprentice to pull the fuses for one circuit on a boat one day then hearing him swear as he caught a jolt. Sure enough he'd only pulled the live fuse and left the neutral fuse behind, leaving the neutral line floating at 120Vac WRT earth! (It was a 240Vac system).
    Sometimes i must admit the frame/skid/chassis that something like an engine is in will be used as an earth return in a boat but only as the earth return for that particular item/assembly and it will be isolated from the ships hull for the reason stated above.
    Hope this helps!
