By process of elimination the 50 ohm resistor is the load resistor. They want to know what values you would choose for R1 and R2 given that the values can range from 0 to 100 ohms each to get the maximum possible power dissipation in the 50 ohm resistor.
This isnt your typical maximum power transfer question either it's actually simpler than that.
If we look at the circuit, since R2 is in parallel with the load when R2 is low it 'steals' power from the load, and so when R2 is at its maximum it 'steals' the minimum possible power from the load.
If we look at R1, when R1 is lowest is supplies the load with the maximum possible power, and when R1 is at max it supplies the most power to the load.
Taking this two arguments together i think you should be able to figure out what the best values are. If not, maybe you should look for another job opening
