It is actually pretty simple.The problem doesn't say that R1 and R2 are either 0Ω or 100Ω, it says that that are merely between those two values, inclusive, and he is supposed to find values that result in the maximum power possible delivered to the load.
At least that's the way I read the problem description.
Yes, the wording is ambigious. It might be that they want three anwers: max power at 50 Ohm resitor, max power at R1, max power at R2.And who is the load? All off them are, I think.
not all of them are load only load resistance 50 ohms is the load.Yes, the wording is ambigious. It might be that they want three anwers: max power at 50 Ohm resitor, max power at R1, max power at R2.
I tried to solve using thevenins theorem & maximum power transfer theorem but i failed to solve.Could you please help me.We can help you AFTER you show YOUR attempt to solve it. That will let us get a glimpse of what approach you are trying and where you are going right and where you are going wrong.
The bad news is that I suspect they were expecting you to be able to answer this question immediately and by inspection. But just telling you the answer won't help you learn the concepts that they wanted to know if you knew. So let's take it one step at a time.
In terms of the variables Vs, R1, R2, and RL, where Vs is the 100V supply and RL is the 50Ω load resistor, what is the power that is delivered to RL? Let's get that far and, once that is correct, we can proceed.
not all of them are load only load resistance 50 ohms is the load.And who is the load? All off them are, I think.
You need to show us what you have done. That is the only way we can help you. I don't understand why you keep repeating yourself.I tried to solve using thevenins theorem & maximum power transfer theorem but i failed to solve.Could you please help me.
Then SHOW us your attempt to solve it that way. Go back and try using the approach I suggested in Post #5. You've been given plenty of hints that should lead you to see the solution by inspection, but the fact that you aren't seeing how to exploit them is a strong indicator that you will be best served by slugging through it. At some point you will have an, "Ah hah!" moment and see the light.I tried to solve using thevenins theorem & maximum power transfer theorem but i failed to solve.Could you please help me.
