Hello!
A signal sent through a copper wire (DC) with between 20-50volts. If you wanted to monitor the signal/plot on a graph:
Can you do this without cutting the wire or attaching a device to the end of it? If yes:
Can you do this without cutting the insulation around the wire? I know that with technology these days you can detect wires behind walls using some electronic devices, but wondered if you could use similar devices to read and boost the signal (like wrapping a caliper around the insulation and getting some faint readings)?
What tools would you need? in either or both cases?
