Solving systems of differential equations - from Kirchhoff's law
Discussion in 'Math' started by Motanache, Mar 3, 2015.
  1. Motanache
    Mar 2, 2015
    108
    5
    Kirchoff law is so clear, that we can write for the variable current.
  2. Motanache
    Mar 2, 2015
    108
    5
  3. Motanache
    Mar 2, 2015
    108
    5
    For this circuit we write equations and we obtain a system of equations.
    How to solve that system of equations ?
    The circuit from below Figure,
    The signal generator provides exponential form.
    The current through Radd is required.
    Any answer, or any suggestion are welcome.
    But wish no offense for other members of the discussion.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    In order to solve the system of equations, you first have to obtain the system of equations to be solved. Have you done this? If so, what did you get?
    Then you can solve them using any valid technique to solve a system of differential equations and there are several. For the systems of equations that result from the analysis of linear systems, the use of Laplace transforms and very common and powerful.
  5. Motanache
    Mar 2, 2015
    108
    5
    Obvious.
    I do not think I took a good example. If I was not wrong at calculations, the problem is easy to solve.
    But I have seen cases in which even with eigenvectors method I could not solve them.:(
    Free online Wolfram Mathematica for the final equation:
    http://www.wolframalpha.com/input/?i=f*y'' + g*y'+h*y = a*b*Exp(b*x)
  6. Motanache
    Mar 2, 2015
    108
    5
    http://en.wikipedia.org/wiki/RLC_circuit
    Another question?
    How they achieved bandwidth (implicitly Q Factor)?
    It can be mathematically demonstrate the bandwidth?
    Why the bandwidth (through Q Factor) depend on reactive power divided by active power?
    When I think of bandwidth, I imagine the voltage function FFT.
