Solving simultaneous equations for mesh analysis
Discussion in 'Math' started by bendi, Jul 6, 2011.
  1. bendi
    Jan 1, 2011
    Hi
    Can anybody advise whether there is an online or down-loadable calculator for mesh analysis solving complex notation such as a + jb using determinants and calculating for two or three unknown variables? Thanks in advance.
    Mark (Bendi)
  2. blah2222
    May 3, 2010
    565
    33
    Matlab will do it.
    bendi likes this.
  3. Robert.Adams
    Feb 16, 2010
    112
    5
    Also, Octave is a free command-line version of MATLAB which will probably do it. Does anyone know if a TI-89 will do it? I've never tried rref() with matrices containing complex numbers.
    bendi likes this.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    The HP graphics calculators will do it.
    bendi likes this.
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    You can do it with python and scipy which are freely downloadable tools:
    Code ( (Unknown Language)):
    1.
    2. from scipy import *
    3. from scipy import linalg
    4.
    5. A = mat("[1 3 5; 2+1j 5 1; 2 3 8]")
    6. b = mat("[10;8;3]")
    7. print A.I*b   # .I means to take the inverse
    8. print linalg.solve(A, b)
    9.
    (note the complex number in the second row of the matrix) which produces
    1.
    2. [[-8.21529745+2.95750708j]
    3.  [ 5.39660057+0.6572238j ]
    4.  [ 0.40509915-0.98583569j]]
    5. [[-8.21529745+2.95750708j]
    6.  [ 5.39660057+0.6572238j ]
    7.  [ 0.40509915-0.98583569j]]
    8.
    The example shows both matrix inversion and a linear equation solver (the solver is preferable because it is numerically more stable).
    bendi likes this.
  6. guitarguy12387
    Apr 10, 2008
    359
    12
    TI-89 will do it!
    bendi likes this.
  7. victorhugo289
    Member
    Aug 24, 2010
    49
    You'll definitely might want to look at Qalculate, it's a calculator for Linux, i use it on Ubuntu all the time, I managed to overwrite the ABC.. constants that have been programmed into it and I used them as XYZ variables so I can solve any equation that uses ABCD..etc variables.
    It solves for values, it factorizes, it simplifies, it's amazing.
    I use it only for simple Algebra, but you can definitely solve the complicated stuff in there.
    bendi likes this.
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    bendi likes this.
  9. jfrost
    Dec 22, 2010
    6
    bendi likes this.
