solving ohms law
purecilia
Joined Dec 29, 2008
12
hello !!!
I am still new to this forum.i have encountered an ohms law question can anyone tell me how shall i work this question it might be really easy for you but for me its a bit complicated considering that i have just started studying electronics..... check this out !!!
mik3
Joined Feb 4, 2008
4,843
First find the equivalent resistance of the two 10 ohm parallel resistors which is 5ohms. Then add it with the two other 10 ohm resistors which are in series with it to get 25 ohms. The current is 2A and thus the voltage is 2*25=50V
purecilia
Joined Dec 29, 2008
12
hi !!
Thanks but now I need to find
1)The voltage across the parallel resistors
2)the power dissipated in resistor A if the value of each resistor was doubled ??
purecilia
Joined Dec 29, 2008
12
I was able to find the voltage across the whole circuit but the question is that I have to find the voltage across the parallel resistors only and I found total resistance, I have to find .....
2)The power disspated in resistor A if the value of each resistor was doubled
purecilia
Joined Dec 29, 2008
12
hello !!
I'll give it atry someone confirm it please ...
V=IR
V=2*5
V=10V
But I still have question 2 please someone help me
