Any help with the problem below will be much appriciated.
Please see attached.
Best regards,
Sara
The approximate solution that satisfies the boundary conditions is:
The below equation should be minimized:
So we have this integral:
Initially, for no deflection, for w = 0, the value of λ from the above equation, is found as:
I can not understand, how λ is calculated.
This is the qustion, how λ is calculated?
Best regards,
Sara
