Solving a equation with help of integration.
Discussion in 'Math' started by Kntte, Oct 2, 2012.
Thread Status:
Not open for further replies.
  1. Kntte
    Oct 1, 2012
    https://plus.google.com/photos/117342881830936664480/albums/5794420642312680769?authkey=CNLKlpiOltKA6gE
    I'm not able to solve this problem, but thought maybe some genius out there would do better:)
    The p in front of the materials Ω pr meter should be a ρ, but I hope that you understood that. I have come to the expression R=ρ*(dx/(phi*r^2)) using the hint, since the formula for resistance in a cable is, R=ρ*(length/cross section). And here dx would represent the length, and phi*r^2 the cross section if you are using the hint.
    But I'm not even sure that is correct. I guess that calling the "length" dx has to to with the integration, but would not dr make more sence, since r has to be the variable here? Or maybe I'm far out now. So if there are any math-genius with some time to spare out there I would really appreciate some help:)
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You are already receiving help with this problem in the homework forum. It's not good practice to jump to another forum if you are not satisfied with your progress.
    Kntte likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Agreed, lets keep the subject over there.
Thread Status:
