Treat your multimeter like a resistor in parallel with your load resistors. This will create 2 resistors in parallel, 30kΩ + 5kΩ = 35kΩ and 70kΩ. Then you can find the current flowing through each leg, and from that obtain the voltage across each.
Is this from a textbook? Or was this generated by a teacher? If it is the former, could you post a screenshot of the question? If it is the latter, then your teacher will have to provide more information for this to be solvable.
If it is randomly generated, then it is almost certainly referring to a diagram that defined the configuration and the variables and the random generation is just coming up with specific values for the problem.
