[SOLVED]Help with PIC18F2550 soldered (sometimes it work, sometime it doesn't)
Discussion in 'Homework Help' started by KansaiRobot, Jun 11, 2015.
  1. KansaiRobot
    Thread Starter Active Member
    Jan 15, 2010
    318
    5
    Hello
    I would really appreciate if you can tell me any idea you get by the following situation. (I really need help :( )
    I have soldered a socket to a board, and put a 18F2550 in it. I have also soldered a circuit in it in which I use pin RB0~RB4. I also soldered RB6,7 to connect to the programmer. I have soldered other necessary components.
    The program I wrote basically gives 1s or 0s to pins B0 to B4. nothing else.
    I have successfully program the PIC.
    Then when I power the PIC sometimes it works, sometimes it doesn't. If it works it keeps working good until turn off (there is no unstability)
    When it doesnt, a small push in the side of the PIC makes it work. Investigating more, when it does not work a touch with a metal to the PIN B5 makes it work. if it is working it makes it not work again!!!
    Now I suspect about the soldering. however here is the strange and bewildering fact:
    I used a oscilloscope to test the PINs directly.(Not the soldered connections) Pin Vdd is receiving 5V successfully. However Pins B0 to B4 are not outputing anything!
    If I touch B5 they start.
    So It is not the soldering or the connections!!!
    What is happening here? Any idea?
    I have run out of possible solutions! :(
  2. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    Is the /MCLR pin connected or floating?
    Max.
  3. joeyd999
    Jun 6, 2011
    2,759
    2,944
    Hopefully not...
    KansaiRobot and djsfantasi like this.
  4. KansaiRobot
    Jan 15, 2010
    318
    5
    it is pull up.
    I ve read that the problem might be pin B5 connected to nothing and me not disabling LVP in the code.
    I ll try this today.
    EDIT: I tried this on a breadboard and the same thing happens. So it is not a matter of soldering...
    When I connect a LED resistor circuit to B5, it does not work of course (as I post in my other thread) but the problem of this thread does not happen.
    So it is a B5 pin problem...sigh
    EDIT2 :It was never a matter of soldering. it turns put that B5 sometimes causes this behavior (reset). So you have to explicitly disable LVP in your code.
    In my case
    Code (Text):
    1. #pragma config LVP = OFF
    and voila! problem solved
