Solve this small problem
Discussion in 'Homework Help' started by salmanshaheen_88, Jun 24, 2010.
  1. salmanshaheen_88
    Thread Starter Active Member
    Mar 5, 2009
    88
    plz solve the encircled part
  2. tskaggs
    Jun 17, 2010
    26
    Part e -
    [x(t)+x(-t)]*u(t)=x(t)*u(t)+x(-t)*u(t)
    The x(t)*u(t) signal is the part of x(t) that is in the RHP.
    The x(-t)*u(t) signal is the part of x(t) that is in the LHP, reversed into the RHP.
    So, the sum of those to signals should be x(t)=0 until t=0. Then a straight line at amplitude 3 from t=0 to 1. And from t=1 to 2 you have a straight line from 1 to -1. The rest of time is x(t)=0.
    Part f -
    x(t)*[\delta(t+\frac{3}{2})-\delta(t-\frac{3}{2})]=x(t)*\delta(t+\frac{3}{2})-x(t)*\delta(t-\frac{3}{2})
    The delta function is basically a sampler. So what you have is a positive sample of x(t) at t=-3/2 and a negative sample of x(t) at t=3/2.
  3. salmanshaheen_88
    Mar 5, 2009
    88
    the answer is below
    so how I will solve these equations??? I solved the first four parts and don't have any concept of remaining two so please solve completely
  4. tskaggs
    Jun 17, 2010
    26
    They're not really equations that you solve, but descriptions of signals. For example, u(t) describes the unit step signal which is defined as the signal whose amplitude is zero at time ranging from negative infinity to 0 and 1 at time ranging from 0 to positive infinity.
    I have attached a pdf that shows drawings of what I am trying to say.
  5. tskaggs
    Jun 17, 2010
    26
    I just realized that on part f I drew the samples backward. At t=-3/2, the signal should have amplitude of -1/2, and at t=3/2 the signal should have amplitude of 1/2. Sorry about that.
  6. salmanshaheen_88
    Mar 5, 2009
    88
    thanks member
  7. salmanshaheen_88
    Mar 5, 2009
    88
    why the value of unit step u(t) is 1 at t>0 ???
  8. tskaggs
    Jun 17, 2010
    26
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It is so by definition. In order to analyze complex waveforms it helps to consider them as being made up of a sum of simple waveforms. The reason they are so useful in linear systems is that in a linear system you can use the principle of superposition to decompose things into simpler forms, solve them, and recombine the results.
  10. salmanshaheen_88
    Mar 5, 2009
    88
    so if the qustion is like [x(2t) + x(-2t)] u(t) so still the value of unit step will be 1???
  11. tskaggs
    Jun 17, 2010
    26
    Like Papabravo was saying... it is a definition. X(2t) is a signal, X(-2t) is a signal and u(t) is a signal. The resultant signal from adding, time distorting, and multiplying does not change the signal itself.
