solve this question plz
Discussion in 'General Electronics Chat' started by munna007, Jun 18, 2010.
  1. munna007
    Thread Starter Active Member
    Jul 23, 2008
    51
    hello to all....
    i m having some doubts in solution of this question....
    what i know about this ckt is that this is pnp transistor. +9 volt is connected to emitter (where arrow made) and -9 volt is connected to collector.
    i think voltage emitter Voltage Ve should be equal to +9 volt , because current source is not dropping any voltage . but in solution part its found something else i.e 1.68 ....
    why is it ???? plz clear my doubt
  2. munna007
    Jul 23, 2008
    51
    sory moderator for posting two times mistakenly .....
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    that is not the Ve voltage.
    It is the Vce Voltage. Collector emmiter voltage
  4. Ron H
    Apr 14, 2005
    7,050
    657
    You are mistaken. The currrent source provides 1mA, regardless of the voltage across it. It does not have to be zero. In fact, the only way for the voltage across a current source to be zero is if it is paralleled by a zero ohm resistor (short circuit), or if (in this case) another 9V source were connected to the bottom end of it.
  5. munna007
    Jul 23, 2008
    51
    in above lines , do u mean that in this circuit current source is not droping any voltage ????
    by connecting another + 9 v at other terminal ,current will not flow . but if we connect -9v then current wil flow. m i right ????
  6. Ron H
    Apr 14, 2005
    7,050
    657
    An ideal current source can deliver current through a short circuit across it.
    However, that is not the issue here. You said
    Maybe I should ask why you think the current source is not dropping any voltage.
  7. munna007
    Jul 23, 2008
    51
    i agree dear that current source has some voltage drop across it...
    but the logic is not clear to me , i have never studied it in any book ????
  8. Ron H
    Apr 14, 2005
    7,050
    657
    A current source is the dual of a voltage source.
    An ideal voltage source can maintain constant voltage, independent of the current through it.
    An ideal current source can maintain constant current, independent of the voltage across it.
  9. munna007
    Jul 23, 2008
    51
    thanks sir , u have really helped me a lot.....:):):):):)
