solve simple problem
Discussion in 'Homework Help' started by devnarayan, Jan 2, 2011.
  1. devnarayan
    Jan 1, 2011
    8
    in given fig. each network have voltage gain 1/2 then voltage gain of cascaded is (a)1/4 (b) 1/5 (c)1/6 (d)1 select correct option. answer provided is 1/5 ,any one can explain how 1/5 is correct
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You'll get a better response in the Homework Forum. I suspect you are new to the board, since you could have modified the other post you made.
    Welcome to AAC!
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Simply find voltage across R4 resistor in this circuit.
    And if you find this voltage you will know that
    VR4 = 1/5 * 1V = 0.2V
      File size:
      6.6 KB
      34
  4. devnarayan
    Jan 1, 2011
    8
    sir why you not directly apply the gain concept since gain of individual network is 1/2 so gain of overall becomes 1/4.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    No, the gain is equal 1/5 because the load effect.
    Second network load the first, and that is why the gain is drop to 1/5.
    The output voltage of a first network will be 2/5
