solve for the radius of an arc.
Discussion in 'Math' started by richbrune, Jul 29, 2006.
  1. richbrune
    Thread Starter Senior Member
    Oct 28, 2005
    106
    I'd like to know the formula for finding the radius of an arc if you know the width of a segment of an arc, and the height of the segment, but you can't measure the whole circle.
    I can't figure out how to reduce the pixel size of a bitmap without freezing the computer, otherwise I'd send a diagram.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Is this what you are looking for?
    http://mathworld.wolfram.com/CircularSegment.html
    hgmjr
  3. Nirvana
    Jan 18, 2005
    58
    Hi there, in order to determine the radius or length of an arc we use the formula. S = r θ, where s is the length of the arc, r is the length of the radius and θ is the angle the radius makes with the arc, in radians , so if you are using degrees then convert it in to radians.
    Hope That Helps
    Nirvana.
