I am new to circuit design and did some searching on the net for solution for converting 5 Volts PWM from a PIC to a 12 Volts PWM. The purpose of the 12 Volts PWM is to be fed into the Gate of a NMOSFET for my Buck converter.
The current situation is that i had a PWM created by my PIC (5 Volts PWM) and a Buck that is trying to control a DC output from 12 Volts to 1 Volts dependent on the duty cycle of the PWM. Due to the Buck requirement, i am running the PWM from the PIC at 400 KHz...
I had tried some of the solutions post in some of the treads, but was not successful in the simulation of those circuits...
Please do kindly assist....
Thanks in advance!
Thanks in advance!
