Solid State
Discussion in 'General Electronics Chat' started by Jsw123, Aug 25, 2009.
  1. Jsw123
    Thread Starter Active Member
    Jun 20, 2009
    43
    Is there a difference between a solid state contactor and a solid state breaker?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A contactor makes a circuit; a breaker opens one. Google will give details.
  3. Jsw123
    Jun 20, 2009
    43
    Does a solid state breaker use mechanical contacts that are swiched by the solid state component to trip when the voltage crosses zero, thereby reducing arc, or does all the load current flow through the solid state component?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    "Solid state" implies no moving parts. Look up "ssr".
  5. Jsw123
    Jun 20, 2009
    43
    If the above is true and there are no moving parts, what would be the difference between a form "B" contactor (normally closed) and a solid state breaker?
    Is it simply that the solid state breaker has to be reset when tripped while a form "C" solid state contactor will reset as soon as power is interrupted?
    I have been looking at google but am still wondering. Thanks!
