I need a solid state equivalent to a DPDT relay that can be used to switch analog video signals, can anyone suggest something?
My current solution works, but I need to make it solid state if possible. I have 2 analog video cameras and 1 video transmitter. I'm currently using a small DPDT relay to select which camera is connected to the transmitter. It switches while the cameras and transmitter are powered up. Does anyone know if a regular solid state relay work with signals as small as an analog video signal without degrading the signal?
